CKopp
Nov 02, 2021Luminary
DNS Issues after firmware upgrade
I recently upgraded to the V1.42.84_1.3.42 firmware verison on my router. Since the update I am seeing random DNS timeout errors (the probe errors). In most cases, the time out is replaced within 1-2...
- Jun 22, 2022
If I enable IPV6, what option should I be using?
Auto Detect?
6 to 4 tunnel or?
ejohnjones
Dec 19, 2021Aspirant
It is absolutely disgusting that netgear is looking the other way on this issue. The problem began with its latest firmware updates and previously there were no issues. NETGEAR knows this issue and is refusing to do something about it. This will be the last NETGEAR product i ever by. Simply because they don't rectify an issue that they caused. Literally happening to almost every router. And the only response from NETGEAR is to downgrade the firmware (to basically an unsecure version considering it was a security patch they were fixing which led me to upgrade).
Shame on NETGEAR for not fixing this.
- RT7900Dec 20, 2021Tutor
This is my 3rd Netgear router. For me DNS is not an option. I may have to look for alternative. Definitely not getting Netgerar anymore.
