CKopp
Nov 02, 2021Luminary
DNS Issues after firmware upgrade
I recently upgraded to the V1.42.84_1.3.42 firmware verison on my router. Since the update I am seeing random DNS timeout errors (the probe errors). In most cases, the time out is replaced within 1-2...
- Jun 22, 2022
If I enable IPV6, what option should I be using?
Auto Detect?
6 to 4 tunnel or?
nnagreg
Apr 18, 2022Apprentice
Yes, I had similar DNS problems, struggling for months.
My solve/resolve tied back into ENABLING IPv6 under the advance settings. See my thread below
With latest version of the firmware V1.4.3.88_1.3.50 and factory reset.
Hope this helps you!
FlyingTs
Jun 14, 2022Tutor
Initial results after enabling IPV6 are positive although very limited testing so far. I was able to open a site that wouldn't even open before. Only Windows 10 showing DNS issues. iPad and Android phone seem to work OK. V1.4.3.88_1.3.50
