derfz
May 20, 2018Aspirant
DNS port forward
Hello all
I seem to be having trouble forwarding DNS to my server.
I have setup port forwarding 53 TCP/UDP to my server IP, but when I test it I only get a responce from TCP. To test I se...
- May 25, 2018
> Read my second post, it does tell you what I did to test.
I don't have an account with BuddyNS, so I assume that I can't use
their "a test service within there consol", and "UDP queries ERROR"
doesn't tell me much, either. I'm far from an authority, but my dim
impression was that UDP was used for DNS much more than TCP, so that if
UDP port forwarding was bad, hardly anything would work. (And, as I
said, "I haven't noticed any problems" around here, but I don't know how
to reproduce your test(s).)
> Although it doesn't say [...]
No, it does say. As I said, I was looking for a way to compare the
behavior of your server with that of mine from an outside-world
location. And, as I complained before, "I have also used several other
internet based DNS test services" was less than helpful.
> I changed my firmware to tomotoUSB [...] I'm thinking of ditching the
> router as this is the obvious problem [...]
You think that the _hardware_ is the problem? That wouldn't be my
first guess.
antinode
May 20, 2018Guru
> I have setup port forwarding 53 TCP/UDP to my server IP, [...]
What is your "my server"?
> [...] when I test it [...]
How, exactly? What happens if you "test it" using the LAN IP address
of your "my server"? Using your public IP address from within your LAN?
> Just wondering if I'm missing something.
At the very least, a clear description of what you're doing.
> Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Is that accurate? Firmware version?
- derfzMay 20, 2018Aspirant
Server: Debian 9 running bind (not that this is relavent)
Secondary DNS server: BuddyDNS. They have a test service within there consol. But I have also used several other internet based DNS test services.
Test results:
StatusComplete
UDP queries ERROR
TCP queries OK
AXFR queries OK
The following tests were done from a different server on the same LAN.
LAN IP UDP test: nc -vz -u local.ip.of.server 53
Response: Connection to local.ip.of.server 53 port [udp/domain] succeeded!
LAN FQDN UDP test: nc -vz -u fqdn.of.server 53
Response: Connection to fqdn.of.server 53 port [udp/domain] succeeded!
Firmware: Firmware Version V1.0.4.12_10.1.46 (up to date)
My lan tests indicate that port 53 TCP/UDP are open and active. However it appears that connections from outside my lan only connect via TCP.
However I cannot rule out that my ISP may be blocking or limiting port 53:UDP inbound requests.
Regards
Fred
I have just spoken with my Internet provider and they have confirmed that there are no blocks on my service.
Hence I beleive that the issue may be with the router given the above tests.
Regards
Fred
- antinodeMay 21, 2018Guru
> Secondary DNS server: BuddyDNS. They have a test service [...]
"buddyns.com"?
> [...] I have also used several other internet based DNS test services.
If you disclosed what you actually did, then I might easily be able
to run similar tests against my D7000, which might tell us if Netgear
ever did this right. (I haven't noticed any problems, but that may
prove little.)
