derfz's avatar
derfz
DNS port forward
Hello all   I seem to be having trouble forwarding DNS to my server.   I have setup port forwarding 53 TCP/UDP to my server IP, but when I test it I only get a responce from TCP. To test I se...
  • antinode's avatar
    antinode
    May 25, 2018
    > Read my second post, it does tell you what I did to test.
       I don't have an account with BuddyNS, so I assume that I can't use
    their "a test service within there consol", and "UDP queries ERROR"
    doesn't tell me much, either.  I'm far from an authority, but my dim
    impression was that UDP was used for DNS much more than TCP, so that if
    UDP port forwarding was bad, hardly anything would work.  (And, as I
    said, "I haven't noticed any problems" around here, but I don't know how
    to reproduce your test(s).)
    > Although it doesn't say [...]
       No, it does say.  As I said, I was looking for a way to compare the
    behavior of your server with that of mine from an outside-world
    location.  And, as I complained before, "I have also used several other
    internet based DNS test services" was less than helpful.
    > I changed my firmware to tomotoUSB [...] I'm thinking of ditching the
    > router as this is the obvious problem [...]
       You think that the _hardware_ is the problem?  That wouldn't be my
    first guess.
