LDDWilliams
Feb 24, 2022Aspirant
DNS_PROBE_FINISHED_NXDOMAIN” error
Ever since I got my new Nighthawk R8000P router, I got DNS_PROBE_FINISHED_NXDOMAIN” error on all webpages on multiple browsers. I called my IP provider and they said it was not an issue on their si...
Feb 24, 2022Guru - Experienced User
what modem/gateway do you have?
do you have IPv6 enabled? If not, enable it and reboot the router.
If so, try using a different ipv4 provider like googles at 8.8.8.8 or 8.8.4.4 or cloudfare at 1.1.1.1
LDDWilliams
I am using the modem that Spectrum provided. It is an Arris.
How do I enable IPV6?
- plemansFeb 24, 2022Guru - Experienced User
what arris is it?
How do I set up an IPv6 Internet connection on my Nighthawk router? | Answer | NETGEAR Support
- LDDWilliamsFeb 24, 2022Aspirant
It is an Arris Touchstone Telephony Modem TM502G
