Bharath_Bekal
Aug 17, 2021Follower
DNS_PROBE_FINISHED_NXDOMAIN Error
My router DNS is configured to Get Automatically from ISP. From past few weeks i get DNS_PROBE_FINISHED_NXDOMAIN while trying to browse new pages for first attempt , if i reload the page it opens. I...
- Dec 11, 2021
If you want to put a bandaid on the problem, in Windows, click on the little wifi icon at bottom right, select Network & Internet settings, click on the adapter you are using (likely Wi-Fi), click on change adapter options, right click on Wi-Fi adapter and choose properties, double click Internet Protocol Version 4, change DNS to use the following DNS server and enter 1.1.1.1 and 1.0.0.1. This will fix the issue until NG releases an update. To reverse this change do the same, but select Obtain DNS server address automatically.
*Rolling back firmware is a security risk so please don't advise that and mark the thread solved. That is not an acceptable solution! This is not solved until NetGear releases a firmware upgraded that addresses the issue!
Feb 16, 2022Guru - Experienced User
What router model do you have?
StealthOne wrote:
I'm also seeing this issue.
Firmware V1.0.4.76_10.1.82
StealthOne
Feb 16, 2022Initiate
Nighthawk X6 R8000
I've downgraded to V1.0.4.68_10.1.75. So far I haven't seen any DNS issues.
- FURRYe38Feb 16, 2022Guru - Experienced User
Thank you for confirming the model and that downgrading helps.
StealthOne wrote:
Nighthawk X6 R8000
