ladyspica's avatar
Dec 08, 2021
DNS_PROBE_FINISHED_NXDOMAIN issue with new firmware update
Hi all, Last week I updated to Firmware 1.2.4.84 and now almost constantly receive error message  DNS_PROBE_FINISHED_NXDOMAIN - I have to reload the sites several times before they appear. Maybe the ...
  • ladyspica's avatar
    ladyspica
    Dec 30, 2021
    Thanks to all for the suggestions. Quick update — tried the DNS setting change and thought that was a fix, but then it wasn’t.
    So, in conclusion, the only real solution is to downgrade your firmware and wait for the issue to be fixed.
    Thanks again to all and hope this helps others with the same issue.
