ladyspica
Dec 08, 2021Tutor
DNS_PROBE_FINISHED_NXDOMAIN issue with new firmware update
Hi all, Last week I updated to Firmware 1.2.4.84 and now almost constantly receive error message DNS_PROBE_FINISHED_NXDOMAIN - I have to reload the sites several times before they appear. Maybe the ...
- Dec 30, 2021Thanks to all for the suggestions. Quick update — tried the DNS setting change and thought that was a fix, but then it wasn’t.
So, in conclusion, the only real solution is to downgrade your firmware and wait for the issue to be fixed.
Thanks again to all and hope this helps others with the same issue.
ladyspica
Dec 08, 2021Tutor
Charter Spectrum Model ET2251 -- is the problem maybe because the modem is old?
I have read through previous posts but there is no clear concise answer.
Are you suggesting a factory reset on the router? Or the modem?
Thank you for your help and quick response.
Dec 08, 2021Guru - Experienced User
No. Just checking to see if there is a router here or not. Your fine here.
Ya, mostly this is a FW issue and needs to be addressed by NG. They are aware of it. No idea when it will be fixed.
Router.
