cosmothunder
Oct 31, 2021Guide
DNS_PROBE_FINISHED_NXDOMAIN
Ever since i updated to the new firmware Firmware Version V1.4.2.84_1.3.42 I've had nothing but issues. problem connecting to websites, problems connecting to discord and certain games jsut no...
- Oct 31, 2021
So if this problem started with a recent firmware update, you can downgrade back one version of firmware to see if the problem goes away...
Oct 31, 2021Guru - Experienced User
What router model are you referring too?
cosmothunder
Oct 31, 2021Guide
Router is Nighthawk X6S
AC3600 Model# R7960P
Modem is Nighthawk CM1100
When i updated my firmware on the router thats when all these problems started.
- FURRYe38Oct 31, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
Power OFF the modem for 1 minute then back ON.- cosmothunderOct 31, 2021Guide
I just did that and still the same. The message "DNS_PROBE_FINISHED_NXDOMAIN" will come up when trying to go to webpages. Sometimes it will resolve itself and go, other times i have to click reload a few times and it goes.
Also i cannot connect to voice on discord servers. Certain games will not load in game content skins, server browsing etc etc. I got certain games to work maybe 2 out of 20 times. I jsut dont get it. Do i need to fully wipe my computer and start with a fresh compy of windows??? I dont know what i did :smileymad:
I would revert back FW Version and see if the problem continues or not.
