cosmothunder
Oct 31, 2021Guide
DNS_PROBE_FINISHED_NXDOMAIN
Ever since i updated to the new firmware Firmware Version V1.4.2.84_1.3.42 I've had nothing but issues. problem connecting to websites, problems connecting to discord and certain games jsut no...
- Oct 31, 2021
So if this problem started with a recent firmware update, you can downgrade back one version of firmware to see if the problem goes away...
cosmothunder
Oct 31, 2021Guide
Slow down there lol tell me in dumdum terms please. Sorry im not that techincal with this stuff
Oct 31, 2021Guru - Experienced User
- cosmothunderNov 01, 2021GuideHow do I roll back the firmware?
- FURRYe38Nov 01, 2021Guru - Experienced User
Download older version of FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
You can find FW files here for yoru model router:
- cosmothunderNov 01, 2021GuideOkay thanks. I will try this tonight. Sorry I'm kindof slow when it comes to this stuff
That worked. Thank you oh wise one!!!
- FURRYe38Nov 02, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
