fehuapaya
Apr 06, 2022Aspirant
DNS_PROBE_FINISHED_NXDOMAIN
hi, My firmware version is V1.0.4.84_10.1.84, but i have the issue DNS_PROBE_FINISHED_NXDOMAIN , this error appear on all webpages on multiple browsers, it is a very uncomfortable problem. I re...
Apr 06, 2022Guru - Experienced User
Netgears aware of the issue. Not sure whats being worked on.
Some fixed it by simply enabling ipv6 and rebooting the router.
Have you tried this?
Others just downgrade a version of firmware.
fehuapaya
Hi,
Thanks for your answer.
Yes i tried uploading 2 old versions but the router dont go back to these versions.
When you refer enable IPv6, this is the work around?
** internet Connection Type from "Disabled" to "6to4Tunnel", the rest I just left as automatic, applied and also rebooted the PC **
thanks
- FURRYe38Apr 06, 2022Guru - Experienced User
v.62 or v.68 are working older versions of FW that can be used.
- plemansApr 06, 2022Guru - Experienced User
did the IPv6 work? I usually just use auto-detect and it works fine.
I do change my ipv6 DNS server as I use pi-hole but it should just auto-detect your isp's dns server.
- fehuapayaApr 06, 2022Aspirant
Hi
I tried with "Disabled" to "6to4Tunnel", work fine around 30min then appear again the message DNS_PROBE_FINISHED_NXDOMAIN, before this IPv6 enable the error occurs inmediately.
Now i tried with the IPv6 Automatic Option, i choose this option, after apply changes appear in 6to4 Tunel, is like the router not refresh this change or choose 6to4 like automatic?.
regards
Its auto detecting that your setup is the 6-4 tunnel.
You might need to downgrade the firmware a version.
