fehuapaya
Apr 06, 2022Aspirant
DNS_PROBE_FINISHED_NXDOMAIN
hi, My firmware version is V1.0.4.84_10.1.84, but i have the issue DNS_PROBE_FINISHED_NXDOMAIN , this error appear on all webpages on multiple browsers, it is a very uncomfortable problem. I re...
fehuapaya
Hi,
Thanks for your answer.
Yes i tried uploading 2 old versions but the router dont go back to these versions.
When you refer enable IPv6, this is the work around?
** internet Connection Type from "Disabled" to "6to4Tunnel", the rest I just left as automatic, applied and also rebooted the PC **
thanks
Apr 06, 2022Guru - Experienced User
v.62 or v.68 are working older versions of FW that can be used.
