fehuapaya
Apr 06, 2022Aspirant
DNS_PROBE_FINISHED_NXDOMAIN
hi, My firmware version is V1.0.4.84_10.1.84, but i have the issue DNS_PROBE_FINISHED_NXDOMAIN , this error appear on all webpages on multiple browsers, it is a very uncomfortable problem. I re...
Apr 06, 2022Guru - Experienced User
did the IPv6 work? I usually just use auto-detect and it works fine.
I do change my ipv6 DNS server as I use pi-hole but it should just auto-detect your isp's dns server.
fehuapaya
Hi
I tried with "Disabled" to "6to4Tunnel", work fine around 30min then appear again the message DNS_PROBE_FINISHED_NXDOMAIN, before this IPv6 enable the error occurs inmediately.
Now i tried with the IPv6 Automatic Option, i choose this option, after apply changes appear in 6to4 Tunel, is like the router not refresh this change or choose 6to4 like automatic?.
regards
- plemansApr 06, 2022Guru - Experienced User
Its auto detecting that your setup is the 6-4 tunnel.
You might need to downgrade the firmware a version.
- fehuapayaApr 06, 2022Aspirant
Hi
Which version?
Firmware Version 1.0.4.76
Firmware Version 1.0.4.74
Firmware Version 1.0.4.68
Firmware Version 1.0.4.66
Firmware Version 1.0.4.62
Firmware Version 1.0.4.58
Firmware Version 1.0.4.52
Firmware Version 1.0.4.46regards
I would try the .76 or .74 version.
