tmag
Aug 21, 2022Aspirant
DNS_PROBE_FINISHED_NXDOMAIN
Such a pain!! I hadn't logged into my router for a time and when I did, it said that I needed to upgrade my firmware. OK, I did. Then, I started receiving these issues: "This site can’t be reache...
- Aug 23, 2022
Just enable it and try the Auto setting. I would reboot the router and all of your devices after you make the change.
tmag wrote:
The modem is from the TimeWarner / Spectrum cable company.
1.0.4.76 is now installed *after* the downgrade.
IPv6 - what setting is required?? I click this option under the Advanced Setup and there is a dropdown...
Again - I am asking for instructions:
- what version firmware *should* be installed and a link to the download?
- what setting under IPv6 is to be chosen?
Thank You
michaelkenward
Aug 22, 2022Guru - Experienced User
Which firmware version installed itself?
The last message in the discussion you link to has a solution. Roll back to what you had before.
There has also been another release since the one discussed in that conversation:
R8000P Firmware Version 1.4.3.88 | Answer | NETGEAR Support
