tmag
Aug 21, 2022Aspirant
DNS_PROBE_FINISHED_NXDOMAIN
Such a pain!! I hadn't logged into my router for a time and when I did, it said that I needed to upgrade my firmware. OK, I did. Then, I started receiving these issues: "This site can’t be reache...
- Aug 23, 2022
Just enable it and try the Auto setting. I would reboot the router and all of your devices after you make the change.
tmag wrote:
The modem is from the TimeWarner / Spectrum cable company.
1.0.4.76 is now installed *after* the downgrade.
IPv6 - what setting is required?? I click this option under the Advanced Setup and there is a dropdown...
Again - I am asking for instructions:
- what version firmware *should* be installed and a link to the download?
- what setting under IPv6 is to be chosen?
Thank You
Aug 22, 2022Guru - Experienced User
What model router do you have? Same model?
What FW version is loaded on the router?
Have you enabled IPv6 on the router?
"This site can’t be reached"
"Check if there is a typo in [insert URL]""DNS_PROBE_FINISHED_NXDOMAIN"
I thought to open a support incident but I can't due to claims that I am "out of warranty". Then I discover the following:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000P-DNS-PROBE-FINISHED-NXDOMAIN-after-updating-Firmware/td-p/2175320
It is *SO* frustrating that this is a *known* issue yet the firmware upgrade still persisted. Then, on top of it, *no* support alternatives offered even though NetGear *caused* the problem.
Jeesh...
