tmag
Aug 21, 2022Aspirant
DNS_PROBE_FINISHED_NXDOMAIN
Such a pain!! I hadn't logged into my router for a time and when I did, it said that I needed to upgrade my firmware. OK, I did. Then, I started receiving these issues: "This site can’t be reache...
- Aug 23, 2022
Just enable it and try the Auto setting. I would reboot the router and all of your devices after you make the change.
tmag wrote:
The modem is from the TimeWarner / Spectrum cable company.
1.0.4.76 is now installed *after* the downgrade.
IPv6 - what setting is required?? I click this option under the Advanced Setup and there is a dropdown...
Again - I am asking for instructions:
- what version firmware *should* be installed and a link to the download?
- what setting under IPv6 is to be chosen?
Thank You
tmag
Aug 22, 2022Aspirant
NetGear
Nighthawk X6
AC3200
R8000-100NAS
Tried getting to the downloads to provide what previous firmware version I had installed vs. what is there now but NetGear has decided to demand an email account verification (as if I hadn't gone through that when I created my account to begin with).
Anyway, I appreciate the responses. However, what I *really* need is:
-- the *exact* firmware version that I should have installed and, preferably, a link to the necessary download
-- any features that I needed to be sure are turned on
-- any necessary directions regarding said features
Thank You
Aug 22, 2022Guru - Experienced User
What FW version is loaded on the router?
Have you enabled IPv6 on the router?
- tmagAug 22, 2022Aspirant
Thank You
- michaelkenwardAug 23, 2022Guru - Experienced User
Yes, but what is it? Spectrum has provided a lot of different devices over the years. They won't all be the same.
IPv6 - what setting is required?? I click this option under the Advanced Setup and there is a dropdown...Again - I am asking for instructions:
How about the bit in the manual?
Specify IPv6 Internet Connections
Maybe try the bit that says select Auto Config?
Your earlier statement is odd:
What does "provide what previous firmware version I had installed" mean?
Provide?
You want to check which version you have installed? Or do you want to download some older version?
There is no need for any email account to get firmware.The whole library for your hardware is on the support pages for the device.
Nighthawk X6 R8000 | AC3200 Tri Band Router | NETGEAR Support
No need for any credentials.
This is the latest version:
- tmagAug 23, 2022Aspirant
Spectrum Model: TC8717T
Ummm... the manual that I have which came with my router does not have what you stated above. I will select Auto-Config and ignore the rest of the settings one page once Auto-Config is selected from the dropdown as none were provided.
Provide?
I wanted to provide herein the previous version of the firmware I had installed which started the issue vs. what I downgraded to. The NetGear website began demanding my email verification which also didn't work. I didn't receive any notifications but it wouldn't allow me to move about the site or look at my account details, etc. Strange... so, yeah, if my responses appeared strange, so did the fact that I upgrade my firmware, it then no longer works as expected and, on top of it, when I log into my account, it demands re-verification *without* properly sending me the verification email...
To me, what's stranger in all of this, one would think it would be easy enough to detail the firmware version that worked *before* the complaints started. What's that?
- FURRYe38Aug 23, 2022Guru - Experienced User
Thank You
OK
