mlevin77
Dec 13, 2019Tutor
DNS stopped working via my R8000?
 I have a Nighthawk R8000 router, and everything was working fine for a couple of years; my clients had its address (10.0.1.1) set as the DNS server in their network setup. In the last 2 weeks, I'm fi...
- Dec 13, 2019
> [...] R8000 [...]
Firmware version? Recently updated?
> [...] why has my router stopped proviing DNS like it used to [...]
Disfunctional router firmware? Does it help to restart the router?
Or to reset its settings, and manually reconfigure the router? Or to
try that with a different/older firmware version?What is the R8000 using as its DNS server(s)? (BASIC > Internet :
Domain Name Server (DNS) Address?) Does it (do they) work properly?> [...] what are best practices for DNS settings on the router and on
> our client devices network setup?It depends, but generally, "Get Automatically from ISP" on the
router, and the same on the clients. (That is, on the clients, use the
router, which is what I'd expect DHCP from the router to give you.)
If your ISP's DNS servers are faulty/unreliable, then specify others
manually on the router.Blame assignment is job one. Change the DNS servers on the router
from the ISP defaults to, say, "8.8.8.8" (and so on). Change a client
device to use the ISP defaults. Does the problem follow the ISP servers
settings, or the use of the router for DNS?
antinode
Dec 13, 2019Guru
> [...] R8000 [...]
mlevin77
Dec 13, 2019Tutor
Firmware V1.0.4.28_10.1.54 , no recent updates.
Changing "Get Automatically from ISP" to 8.8.8.8 and 8.8.4.4 seems to help!
- antinodeDec 13, 2019Guru
> help!Give it a while. It's not unusual for routers running Netgear's fine
firmware to fail hours or weeks after a restart (or settings change?),
so I would not get too optmistic too quickly. But the general scheme is
to change one item at a time in the configuration until you either
recreate the problem, or never see it again. Happy hunting.- mlevin77Dec 13, 2019Tutor
Is there a way to ask it to automatically reboot on schedule? Maybe at midnight every day or few days?
> Is there a way to ask it to automatically reboot on schedule? [...]
Not built in. You could rig an external timer to cut the power
briefly. There are potentially other, unsupported schemes which could
be made to work, but any such would tend to demand computer capability
beyond that of a typical consumer. If you're desperate for
entertainment, then a Web search for terms like, say:netgear telnet enable
might provide some hints.
But any such (sleazy) work-around would destroy the educational
aspects of proper blame assignment.
