archos1
May 22, 2021Aspirant
DNS
Recently I had to reset my NETGEAR R7000 to factory settings. Now after I did a basic setup I want to to change the DNS SETTINGS. I click on Advance then Setup but underneath where it says Inte...
michaelkenward
May 23, 2021Guru - Experienced User
You might find this useful if you want people to see your pictures clearly.
Copy the window or screen contents
Cameras just don't work on screens.
Then read this for an answer to your question:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
archos1
May 23, 2021Aspirant
I thought a picture is 1000 words.Rregardless thanks I will check your suggestion.
- michaelkenwardMay 24, 2021Guru - Experienced User
Absolutely, but it is quicker and easier to tell your PC to create that picture.
No need to aim a camera/phone at the screen, download the (usually a bit wonky) picture to a PC before uploading it to this place.
Use the built-in bit of Windows and you can miss out the "download to PC" step. You end up with an image that is easy to read and that you play around with to obscure sensitive details.
I mention it when people post photos because a lot of people don't realise that there is such a thing as Alt+Print Screen (or Shift+WinKey+S). That simple trick has many more uses than posting to places like this.
- archos1May 24, 2021Aspirant
Hi all, I wish to thank all that help me sort my issue in regard to the DNS settings in my R7000 router.I was all solved by taking the router out of Operation mode: Access mode.
Keep up the good work.I learned a lot out of all your contribution to my issue.
