sgold5's avatar
sgold5
Do routers lose range over time? R7000
Does a ten year old router lose range quality over time?  Will a new model better meet todays wifi needs?  Experienceing some buffering at extended range on Roku device.
AC1900 WiFi Router (R7000)
  • sgold5's avatar
    sgold5
    Oct 02, 2020
    Firmware Version:  V1.0.11.110_10.2.100
    Conducted Speed Test under the QOS Tab.
    Router is wired to PC and sends wireless wifi to all other devices.
    :smileyhappy:
  • plemans's avatar
    What modem do you have?
    What firmware is on the R7000?
    the r7000 isn't known for the best firmware. The agreed upon stable version is the 1.0.9.42 version. You could try installing that, factory reset the router, and then see how it works.
    What do you consider "at range" to the roku?
    Are you connecting via 2.4ghz or 5ghz to the roku? 2.4ghz is much much slower but broadcasts further and through more materials. In my area, its pretty much worthless for streaming because it also suffers from interference.
    • sgold5's avatar
      sgold5
      Currently using Firmware Version V1.0.10.90_10.2.90
      Using 2.4 ghz for longer range.
      Roku connection is Fair located opposite side of house.
      Modem was just replaced by Spectrum (Charter)
      Latest Speed Test:
      Latest test result: Fri Oct 2 13:07:52 2020
       92.42Mbps 11.78Mbps
      Download / Upload
      Thank you for the insight!
