ngconfused
Aug 26, 2022Tutor
Do Standalone Modems Even Exist Anymore?
So, only ISPs can control the firmware on our all-in-one Modem+Router devices. Alright, as bizarre and upsetting as that is, I obviously have no choice, but to accept that. Okay, so the solution ...
- Aug 31, 2022
ALL Cable modems are bound to ISP and get upated by ISPs only. NGs CAX series gateways are ones that users CAN update the ROUTER portion of the modem, however, the modem portion still has to be updated BY the ISP. All other modems or gateway models are updated by the ISP only. There is no user FW update options.
You can do a search with in the DOCSIS Spec and policy if you want additional information as well.
michaelkenward
Aug 27, 2022Guru - Experienced User
ngconfused wrote:
Okay, so the solution is to have a separate modem and a separate router. I'll bite, but how?
I remember in the old days, that was the standard, but now... virtually all the options out there are a single device.
What do you mean by single device? Modem/router?
What sort of Internet?
There are plenty of modem only boxes for cable internet. Netgear is just one brand.
DSL is harder. Netgear and other brands have pulled out of that market for modems and modem/routers. One or two still exist.
Netgear, and maybe others, have started to make modem/routers with separate firmware for the router section. Users can update those.
Is the trick to just think of modems+routers as modems only, disable the router part in the admin, and then connect an additional, separate, but most importantly, router-only router?
That can cause problems, as I discovered using a DSL modem/router in modem-only mode.
Are ISPs pushing to eventually not allow us control over our internet devices, period?
Seems like it. One linesman told me that his operation, OpenReach in the UK, had told ISPs to provide modem/router boxes.
- ngconfusedAug 27, 2022Tutor
Yes! I was actually wondering about that. I think that's the sanest way forward for me. How to do identify which ones aren't beholden to ISPs and allow us to update the firmware ourselves? Is there anything in the marketing or specs language for the respective product that indicates this or is it something someone like yourself has to be savvy to?
