ngconfused
Aug 26, 2022Tutor
Do Standalone Modems Even Exist Anymore?
So, only ISPs can control the firmware on our all-in-one Modem+Router devices. Alright, as bizarre and upsetting as that is, I obviously have no choice, but to accept that. Okay, so the solution ...
- Aug 31, 2022
ALL Cable modems are bound to ISP and get upated by ISPs only. NGs CAX series gateways are ones that users CAN update the ROUTER portion of the modem, however, the modem portion still has to be updated BY the ISP. All other modems or gateway models are updated by the ISP only. There is no user FW update options.
You can do a search with in the DOCSIS Spec and policy if you want additional information as well.
Aug 27, 2022Guru - Experienced User
Who's your isp?
Thats what makes the biggest difference as they're the ones who certify devices for their network.
