ShaunSs
Feb 07, 2021Aspirant
Does Ap mode fix double Nat?
Hello I have an nighthawk R7000 and I am getting double Nat on my Xbox one does turning on access point mode in my router settings fix this problem?
antinode
Feb 07, 2021Guru
> [...] I have an nighthawk R7000 [...]
Connected to what?
> [...] does turning on access point mode in my router settings fix this
> problem?
It might. Cascading multiple NAT routers causes it. Using only one
NAT router (as a NAT router) should eliminate it.
- ShaunSsFeb 07, 2021Aspirant
I have just the 1 netgear night hawk router in my home should i give it an try? Or could i screw something up big time?
it connected to satilite dish out to ISP since i live on an farm it is not wired in
- antinodeFeb 07, 2021Guru
> [...] should i give it an try? [...]
It's ok with me. Worst case: Settings reset and reconfigure it when
it doesn't work. I'd save a configuration file before starting to play
around.> it connected to satilite dish out to ISP [...]
Not a very detailed description of anything, but that stuff could
include a NAT router.
