ShaunSs
Feb 07, 2021Aspirant
Does Ap mode fix double Nat?
Hello I have an nighthawk R7000 and I am getting double Nat on my Xbox one does turning on access point mode in my router settings fix this problem?
ShaunSs
I have just the 1 netgear night hawk router in my home should i give it an try? Or could i screw something up big time?
ShaunSs
it connected to satilite dish out to ISP since i live on an farm it is not wired in
- antinodeFeb 07, 2021Guru
> [...] should i give it an try? [...]
It's ok with me. Worst case: Settings reset and reconfigure it when
it doesn't work. I'd save a configuration file before starting to play
around.> it connected to satilite dish out to ISP [...]
Not a very detailed description of anything, but that stuff could
include a NAT router.- ShaunSsFeb 07, 2021Aspirant
Alright, how would I save an configuration file?
- michaelkenwardFeb 08, 2021Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manage the Router Configuration File.
