Peobody
Nov 24, 2021Guide
Does backup contain password details?
Is there a source the details what information is contained in a configuration backup? I am curious about this in general but was motivated to ask when wondering whether the existing password and as...
Nov 24, 2021Guru - Experienced User
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
One test to check this would be to make a back up, factory reset the router. Load the backup config file and after the reboot, check to see if the PW you had used still works or if the PW reverts to default.
Thank you
Peobody
Nov 24, 2021Guide
Thanks for the pointer to post on the General Routers forum.
As for doing a reset/restore to see what gets restored, I would much prefer to know what will and won't be restored first.
