MichelKesin
Jun 17, 2021Follower
Does factory reset remove the recovery security questions for Netgear?
I bought a used Nighthawk AC 3200 and I have reset the name and password to the default. However, whenever I tried logging into the website to change the WiFi name, there are two security questions...
antinode
Jun 17, 2021Guru
> I bought a used Nighthawk AC 3200 [...]
"AC3200" is a speed, not a model number. Look for "Model" on the
product label.
> [...] I have reset the name and password to the default. [...]
How, exactly?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Types of Logins" and "Reset". Further reading might not hurt,
either.
> [...] whenever I tried logging into the website to change the WiFi
> name, there are two security questions [...]
"tried" how, exactly? The usual cause for getting security
questions is putting in the wrong user name and/or password. A
settings reset (done properly) should restore the default password.
