DeanLaw
Jun 05, 2021Follower
Does my Nighthawk R7000P Do well with cat6?
Hello everyone. I just need an answer: does a Nighthawk R7999P Model AC2300 do well using a cat6 configuration? Thanks?
antinode
Jun 05, 2021Guru
> I just need an answer: [...]
No, you also need a meaningful question.
> [...] does a Nighthawk R7999P Model AC2300 do well using a cat6
> configuration?
Define "do well" and "a cat6 configuration"?
Can you use Cat 6 Ethernet cable with an R7000P and get gigabit/s
speeds? Sure. Or Cat 5e. Or other, higher categories. Or, for lower
speeds, lower categories.
