foxbrady's avatar
foxbrady
Does my R9000 have a built in firewall?
Does my R9000 have a built in firewall? I don't see any settings for it on the dashboard/control panel. Just want to make sure I'm protected.
  • FURRYe38's avatar
    ALL Mfr routers have built in firewalls.
  • > Does my R9000 have a built in firewall? [...]
       Define "firewall".  Any ordinary home/small-office router blocks
    routine access to your LAN from the outside world, unless you take
    explicit steps to allow it (for example: port forwarding).
       If you go out and buy an appliance which is sold as a "firewall",
    then you'll probably get something with many more features.  (Likely,
    many more than you need.)
    > [...] Just want to make sure I'm protected.
       "protected" against what?  You're about as protected as anyone else
    is.
  • FURRYe38's avatar
    I believe he's just making sure that there is a form of a firewall feature on his router. Most routers have a firewall implementation built in.
