phongthuypts
Feb 05, 2023Aspirant
Does Netgear have any plan to fix DNS problem in R8000 1.0.4.84?
All updates after 1.0.4.68, including 1.0.4.84, caused DNS problem where the R8000 router spit out DNS related errors. Older revisions seem to work fine. The problem is using older revision poses...
Feb 05, 2023Guru - Experienced User
Have you enabled IPv6 Auto to see if this helps any on v.84?
We've brought this up to NG.
