NashPhillips
Jan 05, 2022Aspirant
Does Netgear R7000 router cycle in any way once every 60 seconds?
Nighthawk R7000, Firmware V1.0.9.88_10.2.88, Windows 10 ... I have a Bluetooth Stereo Speaker Interference once every 60 seconds. If it's the router cycling, I'd like to know, and if there is a fix I...
- Jan 05, 2022
Greetings,
The router doesn't "cycle" in any way. It runs continiously.
Yours must have something going on with it.
Power supply, incomplete / corrupt firmware, etc.
You should be able to turn wireless broadcasts on or / off individually.
Start by performing a full factory reset.
Wait several minutes and check the logs
If the system is restarting if that's what "cycling" means, you will see it.
Can you now turm your 5G wireless broadcast on?
If not, re-flash 109.88 and retest, following the steps above.
I'm running 1.0.9.42 on my R7000 which I am confident is stable. Try going back to it.
Retest again.
Ensure all wireless boradcasts can be changed, edited, turned off / on, etc
Once done, you can monitor
Once normal operation is established, if the device continues to restart, you should test the power supply with an ohms meter.
shadowsports
Jan 05, 2022Hero
Greetings,
Retest again.
