blackburied's avatar
blackburied
Follower
Jul 08, 2022
Does Nighthawk support USB printers for sharing with Mac OS X?
I've read a lot of discussions here dating many years back to using the ReadyShare software on a Mac to use a USB printer attached to a Netgear Router, and many discussions saying that ReadyShare software (which doesn't run in current versions of OS X) is obsolete and the printer should just show-up when searching the network for printers... but it doesn't.
... aside: an HP 6MP attached via front USB to the Nighthawk router, router interface shows nothing but USB network storage features... nothing about printers.  Mac OS X rev 12.13.
As all discussions about using the Netgear routers for printer sharing are 2015 and earlier, I'm guessing Netgear doesn't support USB networked printers currently in Nighthawk routers?
1 Reply
  • FURRYe38's avatar
    You still have one. I had one of those. Good solid printer.
    Ya, not much support anymore for printers on routers.
    Your best option would be to find a HP JetDirect box to connect the printer too and connect the JetDirect box to the LAN. Thought you may find it hard to find something that takes parallel or small C connections these days.
