GentleHawk
Oct 22, 2021Aspirant
Does R6900P support WPS
My Canon TS8120 printer is having trouble connecting to WiFi and support is asking me to perform these steps: 1. Select Setup on the Home screen (it is the gear icon at the bottom of the LCD screen)...
- Oct 23, 2021
Head to https://www.netgear.com/ from here locate "CUSTOMER CARE" and "Support" which is pointing to https://www.netgear.com/support/ where you can enter the name or model like
...following the link suggested does lead to the R6900P Support page...
...following the [Documentation] button does list the available documentations ...
...magically, there is the User Manual ready to download.
Note: This is about the "standard" concept for many vendors and products, not just for the R6900P.
Magically you might find this (among various WPS related items, like a PIN or soft-button option):
Kitsap
Oct 22, 2021Master
Do you not understand the concept of downloading the manual and reading ???
Go to the Download section at the top of the page, put in your model number and download the manual.
Look at page 11 for a layout of the buttons. Look at page 136 for written instructions.
See attached.
GentleHawk
Oct 23, 2021Aspirant
A helpful reply would have said where to download the manual you quote from.
Kitsap wrote:Do you not understand the concept of downloading the manual and reading ???
See attached.
- KitsapOct 23, 2021Master
GentleHawk wrote:A helpful reply would have said where to download the manual you quote from.
See attached.
Maybe in red and underlined helps !!
