GentleHawk
Oct 22, 2021Aspirant
Does R6900P support WPS
My Canon TS8120 printer is having trouble connecting to WiFi and support is asking me to perform these steps: 1. Select Setup on the Home screen (it is the gear icon at the bottom of the LCD screen)...
- Oct 23, 2021
Head to https://www.netgear.com/ from here locate "CUSTOMER CARE" and "Support" which is pointing to https://www.netgear.com/support/ where you can enter the name or model like
...following the link suggested does lead to the R6900P Support page...
...following the [Documentation] button does list the available documentations ...
...magically, there is the User Manual ready to download.
Note: This is about the "standard" concept for many vendors and products, not just for the R6900P.
Magically you might find this (among various WPS related items, like a PIN or soft-button option):
GentleHawk
Oct 23, 2021Aspirant
The image below shows the row of indicators on the top of the router. My printer manufacturer's instructions for setting WiFi communication with the printer says to "push the WPS button." Is the button pointed to by the red arrow in the image the WPS button?
TOP OF ROUTER
TIA for your help.
GentleHawk.
