GentleHawk's avatar
GentleHawk
Does R6900P support WPS
My Canon TS8120 printer is having trouble connecting to WiFi and support is asking me to perform these steps: 1. Select Setup on the Home screen (it is the gear icon at the bottom of the LCD screen)...
  • schumaku's avatar
    schumaku
    Oct 23, 2021
    Head to https://www.netgear.com/ from here locate "CUSTOMER CARE" and "Support" which is pointing to https://www.netgear.com/support/ where you can enter the name or model like
    ...following the link suggested does lead to the R6900P Support page...
    ...following the [Documentation] button does list the available documentations ...
    ...magically, there is the User Manual ready to download.
    Note: This is about the "standard" concept for many vendors and products, not just for the R6900P.
    Magically you might find this (among various WPS related items, like a PIN or soft-button option):
