Soapstreet
Jan 18, 2017Aspirant
Does readyshare even work on the Nighthawk R7000? USB Drive not detected.
First off. I have at least one usb hard drive that is on the compatibility list. Windows 10 64bit and newest Netgear R7000 firmware. Cant remember the version. I bought the router about 8-10 mont...
- Apr 07, 2017
I got it to work with a 125GB Usb Drive.
irwinsg
Mar 16, 2017Aspirant
R6700 is not on that list
JamesGL
Apr 07, 2017NETGEAR Employee Retired
Hi irwinsg,
You can use the R7000 list as it has the same list.
- GalacticaApr 07, 2017Aspirant
- IrvSpApr 07, 2017Master
I have the USB 2.0 drive working fine in the USB 2.0 port. Also I had used another USB 3.0 drive in the USB 3.0 port. One is a WD, WD1000H1U (1TB 2,0) and the other a Seagate, SRD00F2 (2TB, 3.0).
The are POWERED drives. Many that use the USB port for power, like the Portable USB drives and some Flash/thumb drives generally do not work.
Oh, the R7000 latest flash, 1.0.7.12 seems to have a bug where the USB LCD indicators DO NOT light.
In Windows, open a COMMAND Prompt (Win key + R) and enter CMD then enter NET VIEW. You should see the Router share (default name is Readyshare) like this:
C:\>net view
Server Name Remark
\\IRV8700 Irv's 8700
\\LARAINE-XPS8500
\\READYSHARE readyshare
The command completed successfully.==========
