user444
Aug 30, 2020Aspirant
does setup require an ethernet laptop at the beginning? R7000P
I'm not sure this is the product I will be purchasing, but perhaps. I have a general question about installation. Do I need to have an ethernet enabled laptop to bring to the modem/router cabinet ...
- Sep 05, 2020
If not using the Nighthawk app on your phone to install/setup, here are the instructions for classic installation. Yes, a laptop with ethernet is required with this method. Not so with the app.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
I am hesitant to keep the app and wifi configuration and passwords on my phone security-wise. I did use it for install, but I think I might get rid of it all. All I need for router management is speedtest.net and my PC.
user444
Sep 05, 2020Aspirant
