Deeguy20
Aug 28, 2021Follower
Does the nighthawk m1 have the usb only power feature of the m5
The m5 has this feature that lets you remove the battery and use ac only power, I want to know if the nighthawk m1 has it too. Thanks
1 Reply
Deeguy20 wrote:
The m5 has this feature that lets you remove the battery and use ac only power, I want to know if the nighthawk m1 has it too. ThanksThe m1 is not a standard Nighthawk router of the type covered in this section.
Try here:
Mobile Routers, Hotspots & Modems - NETGEAR Communities
