kdr2
Sep 02, 2021Follower
does the r7000 support the seagate backup plus Hub?
Does any one know if the nighthawk R7000 (from Curriys) support the seagate backu plus hub i tried it acouple of years ago and net gear said they may add it to the list of supported drives, but I can't find the list now!!
1 Reply
Model number? Size?
There seem to be several variants on that.
I use the Backup Plus Hub : SRD0PV1 8TB in an R7800.
I bought it to work on the R7000P, because the database says that would work. But I thought I'd give it a run in the R7800.
The R7800 does not claim that it is compatible, but it is.
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
The R7000 also claims to work with it. So you should be in luck if the SRD0PV1 is what you have in mind.
