Retired_Member
Jun 26, 2021Does this readynas thing work?
Not sure how they can say netgear readynas is a easy backup solution. It is not at all and that is false advertising. I have now thrown numerous backup solutions at it, all fail. Between the limited ...
michaelkenward
Jun 27, 2021Guru - Experienced User
What do you mean by readynas? ReadySHARE Vault?
It works OK here, although it isn't something that I would rely on for heavy duty backups. Netgear has also threatened to kill it in firmware updates.
Readycloud app does zero for me.
Readycloud works fine here too. But I just use it to copy files between two routers on different Internet accounts. Dead easy.
Been trying for days and weeks now, got zero accomplished. I install apps, they do not do anything at all, literally, nothing, all useless.
You don't tell anyone which Netgear hardware you are playing with, so any suggestions have to be based on guessing what your problem is, how it manifests itself and how it might be fixed. All I can say is that things work OK here.
Retired_Member
Jun 30, 2021Well it dont work for me not one bit
- michaelkenwardJun 30, 2021Guru - Experienced User
With no information from you about your system and what you are doing, we are all left guessing.
We don't even know what you mean by "this readynas thing".
Did you come here for help, or simply to complain?
Either is fine. But if it is just "moan" mode, the rest of use can get on with our lives.
