rkruz
Feb 21, 2022Apprentice
Does this router Log entry mean the router blocked the DoS attack?
R6700V3 Firmware Version V1.0.4.126_10.0.102 Router log entry [DoS attack: Smurf] attack packets in last 20 sec from ip [5.167.93.255], Monday, Feb 21,2022 03:45:22
microchip8
Feb 21, 2022Master
NETGEAR's firmware is famous for many, many false positives DoS attacks. Some can even come from your ISP or local PC/Smartphone/Tablet/etc. In case of doubt, look up the IP address and see if it's legitimate. If you're having issues, disable DoS protection (you're not losing much) and see if you get a more stable router. I run for 4 years without DoS protection turned on and never had issues
rkruz
OK thanks. Is there a brand of consumer router that does do a good job with its firewall and reports?
- microchip8Feb 21, 2022Master
ASUS routers are much better at that
