RahulM
Jan 25, 2024Aspirant
DOH on R8000P
Hi, When does netgear planning to add DOH on router. Even my isp issues router has this option. I know the party line answer that it is done at Browser level. But now most of the router except ne...
michaelkenward
Jan 25, 2024Guru - Experienced User
Did you check this place?
Search - NETGEAR Communities – DOH
If it doesn't work already and you expect Netgear to add it to your R8000P, you are probably out of luck. Your R8000P is from 2017.
New features that depend on new hardware don't usually appear on old models.
RahulM
Two question
1. Is my router still support for hotfix and new firmwares?
2. Does any netgear product support DOH?
- RahulMJan 25, 2024Aspirant
BTW DOH being adapted in RFC 8484 (October 2018) almost same time of your product.
- michaelkenwardJan 25, 2024Guru - Experienced UserMy product?
Not guilty. Just another user.- RahulMJan 27, 2024Aspirant
You can ask any fellow member who is not a GURU will tell you that it is your product (the way you defend netgear).
Why don't netgear feel the urge to be with new tech development in industry. (that is why the price of their stock is decreasing consistently in stock market)
