BenHogan
Jul 03, 2022Follower
dont know password to change the passwords
hi! someone hacked into my router and changed the password so i cant change to a different one. can you help me with this?
michaelkenward
Jul 04, 2022Guru - Experienced User
Which password? Router management of wifi?
If you don't know the management password, and the default (see the router's label) doesn't work, the only solution is a factory reset.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
