Juan31
Oct 07, 2021Aspirant
Don't see wifi 6 channel
I've read a similar post here but no answer. Question is why do I not see an option to connect to wifi 6 channel? I have a device that is wifi 6 but no option to connect to wifi 6. Only shows the 2.4 ...
schumaku
Oct 07, 2021Guru - Experienced User
What router model and firmware version please?
Juan31 wrote:
I have a device that is wifi 6 but no option to connect to wifi 6. Only shows the 2.4 and 5g.
What device make, model, WiFi adapter and OS are we facing here?
Suspect you are confused by the designations. WiFi 6 does not say it does support the 6 GHz channels - that would be WiFi 6E.
Juan31
Ax11000 RaxE500 router. Firmware v1. 0.7.68 so what you are saying is even tho I have a device connected to 5g channel it connects as 6g?
- plemansOct 08, 2021Guru - Experienced User
What "wifi 6" device do you have?
Wifi 5 is just 2.4ghz/5ghz.
6E is the 6ghz spectrum.
So letting us know what actual device you have will help us determine if it actually has 6ghz capabilities.
