Juan31
Oct 07, 2021Aspirant
Don't see wifi 6 channel
I've read a similar post here but no answer. Question is why do I not see an option to connect to wifi 6 channel? I have a device that is wifi 6 but no option to connect to wifi 6. Only shows the 2.4 ...
Juan31
Ax11000 RaxE500 router. Firmware v1. 0.7.68 so what you are saying is even tho I have a device connected to 5g channel it connects as 6g?
Oct 08, 2021Guru - Experienced User
What "wifi 6" device do you have?
Wifi 5 is just 2.4ghz/5ghz.
6E is the 6ghz spectrum.
So letting us know what actual device you have will help us determine if it actually has 6ghz capabilities.
- Juan31Oct 08, 2021AspirantI posted that it's the Ax11000 raxe 500 router wifi 6e
- plemansOct 08, 2021Guru - Experienced User
That's the router.
what actual device are you using to try to connect to it?
You have to have a device capable 6ghz to see/connect to 6ghz.
- FURRYe38Oct 08, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi6 Router products. Most of the people who watch that forum are more likely to have experience with NH RAX router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Thank you.
