nickp221
Mar 21, 2019Apprentice
Don't update Nighthawk X10 R9000 to Fireware V1.0.4.28 or you'll brick your router.
Lots of people having problems with this now and should be at the top of the support forum but if you have a Nighthawk X10 R9000 Don't update to Fireware V1.0.4.28 or you'll brick your router.
- Apr 03, 2019
For clarification, please note that V1.0.4.26 does not have the issue of bricking the router. Therefore, factory reset and configuration will work if you have only upgraded to V1.0.4.26. There is no coming back from bricking the router with V1.0.4.28. It will not allow factory reset or downgrade to be applied. You will need to ask for an RMA. Go to https://www.netgear.com/support/contact.aspx and click on "Replace my defective product."
RajaDaja
Mar 27, 2019Luminary
Well, I'm one of the lucky ones. I waited a couple of days after the firmware was released before I installed it. I have no issues. I have auto-update disabled. I also checked the forum for chatter on the lastest firmware before installing. What a bummer for those of you who are having issues after installing V1.0.4.28. I hope Netgear rectifies this.
Regards
