MarMD
Nov 15, 2020Aspirant
DoS Attack disable my wifi
recenly my wifi keep discontecting. i have to reboot to get it back my router is the latest version . i did factory reset which didn't help . i downgraded it to the previous version (see the pic...
DarrenM
Nov 25, 2020Sr. NETGEAR Moderator
Has this continued to happen?
DarrenM
- MarMDNov 25, 2020Aspirant
Disable Port Scan and DoS Protection didn't help
i did change the default MAC address of the router this actually helps. I am still having those “DoS Attack: ACK Scan” i have not noted any disconnection however based on a log file it happened overnight a starting of Firmware which may indicate a router reset. instead of happening every hour, now it is happening every two days which is good somehow . netgear has to work in fixing this issues in its next firmware upgrade
