MarMD
Nov 15, 2020Aspirant
DoS Attack disable my wifi
recenly my wifi keep discontecting. i have to reboot to get it back my router is the latest version . i did factory reset which didn't help . i downgraded it to the previous version (see the pic...
DarrenM
Nov 25, 2020Sr. NETGEAR Moderator
Has this continued to happen?
DarrenM
MarMD
Nov 25, 2020Aspirant
Disable Port Scan and DoS Protection didn't help
i did change the default MAC address of the router this actually helps. I am still having those “DoS Attack: ACK Scan” i have not noted any disconnection however based on a log file it happened overnight a starting of Firmware which may indicate a router reset. instead of happening every hour, now it is happening every two days which is good somehow . netgear has to work in fixing this issues in its next firmware upgrade
