MangoChocobo
Dec 14, 2020Aspirant
DOS ATTACK drops internet completely
Background: I've tried many things from forums, I know these are false positives as they are from places like Microsoft, Amazon, and Valve(or steam) I just don't know why it keeps disconnecting ...
michaelkenward
Dec 14, 2020Guru - Experienced User
There is only one DoS attack in there. Hardly enough to bring the thing to its knees. I assume that there are more somewhere.
Have you tried disabling the logging of those events?
They may put a strain in the router's processor which could explain the behaviour.
Also disabling things like QoS and the traffic meter. They also use processor power.
- MangoChocoboDec 14, 2020Aspirant
Thanks for quick reply, I have it logging everything and I believe Traffic meter is on, I'll turn those off and get back to you.
I know it's hardly enough thats why its just weird, cause it'll always be just one false positive then down for like 1 min, and back up again.- MangoChocoboDec 15, 2020Aspirant
Happened again, much later than usual, but still, wipeed internet off, Did you mean for me to basically have it not log at all or just the "DOS attacks"
- michaelkenwardDec 15, 2020Guru - Experienced User
Up to you.
To begin with I'd disable Dos attack logging and see what happens.
Logging does nothing for the protection. So disabling it does not add to the danger.
Of course, there may be something completely different going on.
