firefox111
Sep 13, 2021Apprentice
"DoS attack: Fraggle Attack" almost every 10 seconds
Hello. I replaced an aging gateway firewall/router/gateway lately and my Nighthawk X6S has plenty of this Fraggle Attack in its Log. Does anyone know what is this? What port/s does this pertain to...
michaelkenward
Sep 16, 2021Guru - Experienced User
FURRYe38 wrote:
Then a reset wouldn't be disruptive if you have a back up.
But restoring settings from a backup is a well known way of bringing bugs back from the grave.
First reset, then see if the problem has gone away. If it has, restore the settings.
If restoring brings back the issue, then you know that you will have to steel yourself to a reset and a full reconfiguration.
Yep. what I usually recommend.
