Nottechatall
Mar 04, 2021Aspirant
Dos attack
Hi So my internet has been dropping today - im with Virgin Media - so i know theyre having issues atm with TV & phone but not showing any issues on their own website for internet my area. Checked m...
microchip8
Mar 04, 2021Master
A lot of these entries are false positives. NETGEAR is notoriously known for producing false positives and thus straining the router. I'd suggest turning off DoS protection and see if it fixes the issue you have
- NottechatallMar 04, 2021AspirantThanks will give it a try 👍🏻
- michaelkenwardMar 05, 2021Guru - Experienced User
A safer option might be to turn off logging of DoS attacks. This does nothing to change the function of the device.
- Advanced
- Administration
- Logs
- Uncheck "Known DoS attacks and Port Scans"
The logging uses up processor time and that can lead to the crashes and slowdowns that some people experience.
Turning off QoS and other processor intensive features, such as traffic metering, can also help.
- microchip8Mar 05, 2021Master
michaelkenward wrote:
microchip8 wrote:I'd suggest turning off DoS protection and see if it fixes the issue you have
- Advanced
- Administration
- Logs
Actually, logging is cheap but blocking/filtering with the Linux firewall which is used for DoS prevention is expensive CPU-wise. I run Linux at home on 4 PCs and know very well how iptables behaves when you're dealing with a large set of IP blocking/filtering, especially on routers with limited processing power. Turning off logging will give you a false sense of "security" due to the large amount of false positive. Logging off is not enough to relieve the CPUs on these routers
