Grogie1977
Mar 07, 2021Tutor
DoS Attacks and False Flags
There are a lot of discussions of DoS attacks and what they mean and where they come. Comments from "why would someone want to attack a lonely computer and not business?" to ISP's not have good security and false flags Now, I do agree with the waste of time attacking and flooding a lonely computer but I have had issues with DoS attacks myself. These DoS on my router have caused internet drops, lags and errors. I have found these DoS to be growing. I recently upgraded from a Netgear Nighthawk X8 R8500 to an Netgear Nighthawk AX8 RAX70 6600 and I see more DoS attacks/scans. Netgear Armor was activated but (like others) having an issue connecting it to my router, so I can't tell if that will help or not. A lot of these IP's are registered to Amazon, Akami, tech companies, google and others. So, you may want to call them false flags but are they doing probing/scanning port 20/80/443 security ports? They have no reason to unless they are looking information or to steal information from you. So, false flag or not, this is an issue and something that shouldn't be set be set asside. Did Netgear put this code into the routers by mistake? Why have they not changed this coding after all these years and all of these complaints to stop false flags? Because it isn't and all of these IP's are stealing INFO and it needs to stop. My internet lags, disconnects and gets errors. Mine are constant.
[admin login] from source 192.168.1.2, Sunday, March 07, 2021 19:34:52
[DoS Attack: RST Scan] from source: 104.104.86.182, port 443, Sunday, March 07, 2021 19:33:46
[DoS Attack: TCP/UDP Chargen] from source: 146.88.240.4, port 41003, Sunday, March 07, 2021 19:31:09
[DoS Attack: RST Scan] from source: 17.137.160.100, port 443, Sunday, March 07, 2021 19:31:07
[DoS Attack: RST Scan] from source: 52.52.27.179, port 443, Sunday, March 07, 2021 19:30:59
[DoS Attack: RST Scan] from source: 23.32.169.191, port 443, Sunday, March 07, 2021 19:29:14
[DoS Attack: RST Scan] from source: 173.223.66.25, port 443, Sunday, March 07, 2021 19:29:13
[DoS Attack: RST Scan] from source: 104.102.251.83, port 80, Sunday, March 07, 2021 19:23:56
[DoS Attack: RST Scan] from source: 104.102.251.83, port 80, Sunday, March 07, 2021 19:23:55
[DoS Attack: RST Scan] from source: 142.250.64.67, port 443, Sunday, March 07, 2021 19:21:40
[DHCP IP: 192.168.1.4][Device Name: TIVO-A950938F592EC86] to MAC address a8:f5:dd:c1:3a:af, Sunday, March 07, 2021 19:21:08
[admin login] from source 192.168.1.2, Sunday, March 07, 2021 19:20:52
[admin login failure] from source 192.168.1.2, Sunday, March 07, 2021 19:20:38
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 19:13:55
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 19:11:28
[DoS Attack: RST Scan] from source: 104.112.12.26, port 443, Sunday, March 07, 2021 19:03:18
[DoS Attack: RST Scan] from source: 104.112.13.33, port 443, Sunday, March 07, 2021 18:59:38
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:58:51
[DoS Attack: RST Scan] from source: 172.232.6.41, port 443, Sunday, March 07, 2021 18:58:18
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:57:07
[DoS Attack: RST Scan] from source: 104.112.14.103, port 443, Sunday, March 07, 2021 18:56:09
[DoS Attack: RST Scan] from source: 104.112.12.26, port 443, Sunday, March 07, 2021 18:55:58
[DoS Attack: RST Scan] from source: 104.102.251.83, port 80, Sunday, March 07, 2021 18:53:56
[DoS Attack: RST Scan] from source: 104.102.251.83, port 80, Sunday, March 07, 2021 18:53:55
[DoS Attack: SYN/ACK Scan] from source: 51.222.26.69, port 22, Sunday, March 07, 2021 18:52:26
[admin login] from source 192.168.1.2, Sunday, March 07, 2021 18:52:26
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:47:23
[DoS Attack: RST Scan] from source: 199.232.38.217, port 443, Sunday, March 07, 2021 18:46:21
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:45:47
[DoS Attack: RST Scan] from source: 52.149.246.247, port 443, Sunday, March 07, 2021 18:45:19
[DoS Attack: RST Scan] from source: 52.149.246.39, port 443, Sunday, March 07, 2021 18:45:18
[admin login] from source 192.168.1.2, Sunday, March 07, 2021 18:44:42
[DoS Attack: RST Scan] from source: 38.134.110.225, port 443, Sunday, March 07, 2021 18:43:04
[DoS Attack: RST Scan] from source: 3.218.90.66, port 443, Sunday, March 07, 2021 18:42:55
[DoS Attack: RST Scan] from source: 192.96.200.41, port 443, Sunday, March 07, 2021 18:42:54
[DoS Attack: RST Scan] from source: 69.166.1.10, port 443, Sunday, March 07, 2021 18:42:48
[DoS Attack: RST Scan] from source: 69.166.1.15, port 443, Sunday, March 07, 2021 18:42:47
[DoS Attack: RST Scan] from source: 141.226.224.32, port 443, Sunday, March 07, 2021 18:42:46
[DoS Attack: RST Scan] from source: 13.225.209.20, port 443, Sunday, March 07, 2021 18:40:56
[DHCP IP: 192.168.1.2][Device Name: LAPTOP-P55IVV86] to MAC address 34:e1:2d:4b:0d:98, Sunday, March 07, 2021 18:38:27
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:37:00
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:34:41
[DoS Attack: TCP/UDP Echo] from source: 111.7.96.148, port 32983, Sunday, March 07, 2021 18:30:35
[DoS Attack: TCP/UDP Chargen] from source: 193.118.53.132, port 24062, Sunday, March 07, 2021 18:27:34
[DoS Attack: RST Scan] from source: 199.232.38.133, port 443, Sunday, March 07, 2021 18:25:54
[DoS Attack: RST Scan] from source: 142.250.64.67, port 443, Sunday, March 07, 2021 18:24:16
[DoS Attack: RST Scan] from source: 54.192.103.123, port 443, Sunday, March 07, 2021 18:16:05
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:15:24
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 18:06:58
[DHCP IP: 192.168.1.8][Device Name: TIVO-D6900F5362FB141] to MAC address 20:f1:9e:05:df:fd, Sunday, March 07, 2021 18:04:57
[admin login] from source 192.168.1.2, Sunday, March 07, 2021 18:04:39
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 17:59:01
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 17:58:31
[admin login] from source 192.168.1.2, Sunday, March 07, 2021 17:57:01
[DHCP IP: 192.168.1.9][Device Name: TIVO-A950AC36C6A3D88] to MAC address f0:af:85:8c:5e:69, Sunday, March 07, 2021 17:56:58
[DoS Attack: SYN/ACK Scan] from source: 51.255.122.138, port 80, Sunday, March 07, 2021 17:55:14
[DoS Attack: RST Scan] from source: 23.109.103.84, port 28015, Sunday, March 07, 2021 17:54:43
[DoS Attack: SYN/ACK Scan] from source: 23.109.103.84, port 28015, Sunday, March 07, 2021 17:54:31
[DoS Attack: SYN/ACK Scan] from source: 23.109.103.84, port 28015, Sunday, March 07, 2021 17:54:25
[DoS Attack: SYN/ACK Scan] from source: 23.109.103.84, port 28015, Sunday, March 07, 2021 17:54:22
[DoS Attack: SYN/ACK Scan] from source: 51.255.122.138, port 80, Sunday, March 07, 2021 17:52:52
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 17:52:01
[DoS Attack: RST Scan] from source: 13.225.65.16, port 443, Sunday, March 07, 2021 17:51:22
[DoS Attack: RST Scan] from source: 104.112.8.164, port 443, Sunday, March 07, 2021 17:50:29
[DoS Attack: RST Scan] from source: 185.159.159.170, port 443, Sunday, March 07, 2021 17:50:19
[DHCP IP: 192.168.1.2][Device Name: LAPTOP-P55IVV86] to MAC address 34:e1:2d:4b:0d:98, Sunday, March 07, 2021 17:50:18
[DoS Attack: RST Scan] from source: 69.166.1.10, port 443, Sunday, March 07, 2021 17:50:15
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:50:03
[DoS Attack: RST Scan] from source: 3.218.90.66, port 443, Sunday, March 07, 2021 17:49:35
[DoS Attack: RST Scan] from source: 3.218.90.66, port 443, Sunday, March 07, 2021 17:49:11
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:49:10
[DoS Attack: RST Scan] from source: 204.154.110.149, port 443, Sunday, March 07, 2021 17:48:54
[DoS Attack: RST Scan] from source: 204.154.110.149, port 443, Sunday, March 07, 2021 17:48:53
[DHCP IP: 192.168.1.2][Device Name: LAPTOP-P55IVV86] to MAC address 34:e1:2d:4b:0d:98, Sunday, March 07, 2021 17:48:40
[DoS Attack: RST Scan] from source: 52.45.33.138, port 443, Sunday, March 07, 2021 17:48:40
[DoS Attack: RST Scan] from source: 69.166.1.10, port 443, Sunday, March 07, 2021 17:48:29
[DoS Attack: RST Scan] from source: 52.45.33.138, port 443, Sunday, March 07, 2021 17:48:20
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:48:07
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:48:06
[DoS Attack: RST Scan] from source: 52.45.33.138, port 443, Sunday, March 07, 2021 17:48:03
[DoS Attack: RST Scan] from source: 69.166.1.10, port 443, Sunday, March 07, 2021 17:47:57
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:47:35
[DoS Attack: RST Scan] from source: 54.175.87.114, port 443, Sunday, March 07, 2021 17:47:31
[DoS Attack: RST Scan] from source: 185.167.164.42, port 443, Sunday, March 07, 2021 17:47:29
[DoS Attack: RST Scan] from source: 54.175.87.114, port 443, Sunday, March 07, 2021 17:47:12
[DoS Attack: RST Scan] from source: 54.188.133.192, port 443, Sunday, March 07, 2021 17:46:12
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:45:51
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:45:50
[DoS Attack: RST Scan] from source: 69.166.1.10, port 443, Sunday, March 07, 2021 17:45:20
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:45:19
[DoS Attack: RST Scan] from source: 104.96.251.116, port 443, Sunday, March 07, 2021 17:45:18
[DHCP IP: 192.168.1.6][Device Name: RICHARDS-IPHONE] to MAC address c2:10:3a:b7:0c:b4, Sunday, March 07, 2021 17:42:40
[DoS Attack: RST Scan] from source: 17.188.142.166, port 443, Sunday, March 07, 2021 17:42:40
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 17:42:34
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 17:39:27
[DoS Attack: RST Scan] from source: 193.122.130.38, port 443, Sunday, March 07, 2021 17:38:16
[DoS Attack: RST Scan] from source: 68.67.161.182, port 443, Sunday, March 07, 2021 17:38:01
[DHCP IP: 192.168.1.5][Device Name: IPHONE] to MAC address f2:62:90:82:74:6d, Sunday, March 07, 2021 17:37:32
[DoS Attack: RST Scan] from source: 100.24.81.70, port 443, Sunday, March 07, 2021 17:37:31
[DoS Attack: RST Scan] from source: 205.185.216.10, port 443, Sunday, March 07, 2021 17:37:11
[DoS Attack: RST Scan] from source: 69.166.1.10, port 443, Sunday, March 07, 2021 17:37:01
- microchip8Master
NETGEAR is famously known for many false positives. Blocking/filtering these false positives is expensive and puts a lot of strain on the limited resources of the router. Try to turn off DoS protection and see if it fixes your issues
- This is what I ended up finding out these router DoS router attacks and rst scans. Sorry for some you computer geeks (lol) who have computer knowledge, I wrote this informative paragraph for another group. Though this will stay informative to wide range of users left in this form. Here is something that know news or tech company will tell you. A large tech company, Akemai, is involved with Adobe, IBM, Microsoft, Intel, AVG and others for download managers. In other words, Intel Update Manager and various update apps to tell you when updates are available. Theses apps are constantly sending out messages to Akemai asking if there are updates and the way Akemai sends the response back is blocked by the routers firewall. This is known as DoS (denial of service). If you log into your router and look at your logs under admin you should see DoS rst scans with an ip address. If you search that ip address that address should come up as Akemai owned. Also if you open up your task manager, go to performance then network you will see constant out going traffic when you are not on the internet. How to fix this? Open your ports on the router firewall which is a security risk and not recommended. Companies resolving the issue, which won't happen time soon. So, for adobe you have to go to the search are and type services and open it up, find Adobe update and disable it. Any other update app you will have to disable or uninstall, this is bloatware. You can check weekly or monthly yourself. There is also programs like Drive Booster that will monitor all your apps and not hinder performance. It is only one program and not many. The more computers on a network, the more rst scans DoS you will have on your router. I don't believe turning off DoS scans is ever a wise answer. This is the same as opening up ports and opening you up to security attacks. Either take the risk in some peoples advice of this or just get rid of these download managers.
